Twin Cam Motors Twin Cam 1998 thru 2017
Engine noise
Old Today | 12:49 AM
Guuuuns's Avatar
Guuuuns
Originally Posted by Jackie Paper
Two ear mechanic's stethoscope. Under $10 at Harbour Freight. You need both ears plugged from all the exhaust noise to determine engine problems. Compare one cylinder to the other in the same location on each cylinder.
I don't hear any great problem. And I do detect different sounds mixed together that without the two ear stethoscope is confusing.
A broken ring would cause a issue in how it idles. However on a Harley, that's difficult to see.
Do a warm compression check with butterfly held open. See a problem, then double check with a leak down to see if it's rings or valves.
What is a cam service kit?
Thank you for your answer. I was also a mechanic. Now I do it as a hobby. The product in the picture is a cam service kit.
taco_bandit
Twin Cam Motors
16
05-17-2023 11:55 PM
Ro33
Twin Cam Motors
11-06-2022 11:18 AM
Cohiba_Joe
10-26-2020 08:17 PM
twig
Milwaukee Eight (M8)
24
11-13-2019 08:04 PM
JONNIEROCK
12-30-2013 06:35 PM
Quick Reply: Engine noise
