Twin Cam Motors Twin Cam 1998 thru 2017
Strange problem with my TC88
Old 08-12-2024, 05:09 AM
TimJ2110's Avatar
TimJ2110
TimJ2110 is offline
So i changed the check valve, fuel filter and regulator.
The bike got a bit better, but not 100%.
So, is there anything else that should be checked?
Old 08-29-2024, 02:35 PM
TimJ2110's Avatar
TimJ2110
TimJ2110 is offline
So, a quick update on my issue.
I saw that there was a lot of oil on my air filter and remembered that I had overfilled the engine oil the last time I changed oil...
So after cleaning the IAC valve and the MAP sensor with some carb cleaner, the issue went away.
I will redo the breathing on the bike, so it breaths into a catch can instead of in to the intake, I guess that this will solve the problem for the future.
pgreer (08-29-2024)
Old 08-29-2024, 04:51 PM
Rounders's Avatar
Rounders
Rounders is offline
Received 2,328 Likes on 1,842 Posts
I have used brake clean, but I believe you are supposed to use sensor cleaner. I bought a can, it was cheap, will last for years.
Old 09-27-2024, 09:51 AM
TimJ2110's Avatar
TimJ2110
TimJ2110 is offline
So... The problem came back..
The bike run great after cleaning the MAP Sensor and IAC valve, but that didn't last for long.
The bike started acting up again, so I tried cleaning the throttle body once more, but this time no success....
Im getting hella frustrated now, thinking of just carving the f... thing and move on....
skully1200
08-09-2013 02:39 AM
BluBeaSSt
10-14-2012 10:20 PM
azharleyrider86401
09-29-2011 06:44 PM
jeffer60
08-14-2009 09:05 PM
drumer66
05-06-2007 01:58 PM
Quick Reply: Strange problem with my TC88
