Rebuilt Fuel tank quick disconnect. Now won't run
2007 softail springer sat for 5+ years.
Drained tanks, and added new fuel in gas tank and a wee shot of starting fluid and she started instantly and ran fine.
I decided to pull off the quick disconnect on the left bottom of the fuel tank to clean it, and it had bad leaky O Rings and so bought a rebuild kit and the Fuel Tool Check valve rebuild kit MC 400. Replaced both orings, spring and valve. It doesn't leak any more and the quick disconnect works well. When I remove the quick disconnect there is good pressure I think because a small amount of fuel sprays out under pressure. Seems to be ok.
When I try to start the bike now after the quick disconnect rebuild it is getting no fuel to the engine. If I shoot starter fluid in, it instantly starts but dies. Clearly no fuel.
Ideas?
Not sure what I did that caused this?
Ideas?
The following 3 users liked this post by Jackie Paper:
