Oil pump alignment necessary?
I don't recall roll /alignment pins on the camplate. So theoretically, the bolts which are not tight tolerances, could leave the plate to move slightly when reinstalled. that said, and Max stated,it would be easy to do the loosen bolts, turn the engine by hand and tighten again to be sure it finds its happy place.
