Annoying newbie 124 build questions
Hi everyone. Im sure this has been beat to death but I recently came into a stock 103 I want to build into a 124ci for my 2013 FLHX me too bike. It's pretty much my daily driver so I'm going for something fun yet bulletproof. I've already bought a Fueling cam chest kit I was going to put in my current 103 but decided to save it for the 124 build. I've been doing some research but keep seeing conflicting parts info or I'm just sucking in too many exhaust fumes to understand?? I know I have to get the case bored for the bigger 124 jugs. Looking at crankshafts Ive read I need a 4 5/8 stroke and to get a set of 110 heads. What pistons and cams would be recommended? Open to mean and helpful info and shenanigans. Does this look like a rash to you? It itches and smells funny
Rollbar (03-02-2024)
By the time you are done the only thing original to the 103 motor will be the cases. They will need boring and you may want timken conversion.. You'll want the 110 heads ported. At that point wouldn't it be easier to simply buy an SnS 124 motor. You might want to try a hot rod 110 or even 107 instead, using bored stock cylinders.
Consider a 117- they have been shown to be reliable as a daily driver, using the shorter stroke but the same bore as the 124s. Rebuild your flywheels if they need it, bore your cases, use the Fueling cam chest pieces, pick a cam that works in your preferred range, clutch/intake/exhaust to match, tune and enjoy!
The following 5 users liked this post by rigidthumper:
13SG124 (03-04-2024),
Lonewolf176 (03-02-2024),
Max Headflow (03-02-2024),
Rollbar (03-02-2024),
Sweep'r (03-02-2024)
Yeah I was thinking that too, then you can save the heads (still need porting) and the crank.. I guess in both cases you also save the cam cover and rocker stuff.
rigidthumper (03-02-2024)
