Push Rods and Cam Tensioner parts list: 05 Deluxe 88
Not necessarily. Like Meatball says, heat the cam plate assembly, with cams, and the cams, with bearings will fall out. That way there has been no pressure on the outer cam bearing race and no need to replace the outer cam bearings. It is your call whether or not you want to replace the inner cam bearings. Once the tensioners have been addressed, you can freeze the cams, with the outer bearings, heat the cam plate again and drop the cams/bearings back into the cam plate. The inner chain will be on and the timing marks on the cam sprockets must be aligned. Unless you have a "special" tool, the cams have to come out to replace the inner tensioner. It's not rocket science.
'05 Twin Cams were still running the HD "B" lifters which were probably the best of the OEM lifters. Service manual says service life is 25K-30K miles, so a toss up IMHO. If budget allows, replacing them with a set of Johnson Hy-Lifts from WFO Larry would be an upgrade. He offers 3 lifters 2313, 2313S and 2313SE; the standard 2313 lifters would be fine with you application; your call. https://www.larrysmotorcyclemachine.com/lifters.html
It is a while you are there kind of thing, but a quite good one.
The original bearings have plastic cages keeping the needles in position, and they can fail with catastrophic consequences. The Torrington bearings are filled with needles without plastic separators and are very unlikely to fail.
You do need a special tool for removing and installing them, I have always managed to rent or borrow them, you could check with a local workshop or motorcycle club maybe.
Are these the ones ? so they are both the same bearing for left and right cam?
Well I finally have new Torrington inner bearings, tensioner pads and associated seals with the push rod removal through the rocker box process. Thanks for everyone who commented and helped out. I started an ape hanger install in the midst of this so I haven't been able to check my work and start the bike yet. I'll dive into the manual and see what the process is for adding oil back and starting. I'll post the ape install somewhere when complete. Thanks again. Until next time......
