Used Purchase: Dealer Inspection
Since the 99-05 Twin Cams are to be considered faulty from the factory, the cam chain tensioners are a design flaw that most manufacturers would have replaced for free as a good will repair, in my opinion the dealer should at least offer to remove the cam cover so you can inspect the state of the tensioner pads yourself.
It's not a big job, remove exhaust and cover. Add a gasket and some engine oil. They should do that for free.
You are purchasing a bike HD dealers will not even work on. All they want is you to purchase it and go away.
They will tell what ever it takes for you to sign on the line. Then take it and anything else they get you to purchase and show you the door.
I do not understand anyone buying a bike the dealer will not even support.
John, if it runs OK, a 05 without record history is a gamble.
If you buy it, just replace the tensioners, oil pump and inner cam bearing. Your good for a long time.
I have a 04 Softail retired sitting in VA. It has little over 50,000 on it. Not long ago, I syphoned all the fuel out, replaced the fuel, put the battery in and got my son to put some miles on it.
Runs like new. Has the original tensioners in it.
Even in 07 or so with the roller chain and hydraulic system, the tension pads are just too small. Look at the tension pads on a M8.
On a well designed chain system, a roller chain outer links groove in and then the rollers roll. Wear stops. Hopefully, the M8 will do that.
Your 05 is fine if ridden like the cruiser it is.
If what you're paying for it is a concern, your in the wrong hobby.
Only millionaires should buy antiques if they can't work on it.
touchdown (02-22-2024)
The early TC with link chain wore and never stopped wearing shoes till they were replaced or broke.
The first generation of roller chains on the TC did the the same since shoe was to thin to allow rollers to roll. The hydraulic plunger broke through the center of the shoe.
What generation or year of the TC did Harley get the shoes thick enough to let chain rollers roll and stop wearing?
Link chain (some call silent). And cavitatation from high RPM. Even with reasable RPM, wear never stops.
First generation roller chains or either a inner link chain on a hydralic conversion. Not sure?
If thick enough, with a roller chain, rollers roll and wear stops.Rolle chain on bike.
Link chain. My Harley at 30,000. There still in there at 50,000. links have a orange peel bumpy face. Cuts down cavitation I think. My shoes were smooth.
Lose something to get something?
The early TC with link chain did this and never stopped wearing shoes till they were replaced or broke.
The first generation of roller chains on the TC did the second attachment.
There really isn't a reasonable priced upgrade. Even Harleys so called upgrade leaves an inner link chain since sprocket is part of cam shaft.
Link chain sprocket
Roller chain sprocket.
To start with the Frame allowing better tires. and more. The front end,6 gallon tank. TC96 standard 6 speed
