Twin Cam Motors Twin Cam 1998 thru 2017
Mild 117 build cam
Old 11-24-2023, 12:42 PM
pawhite's Avatar
pawhite
pawhite is offline
Originally Posted by harpwrench
I think in the UK you might be better off doing a very responsive 107 than diving into a 117 rabbit hole.
Thanks for your input but can you elaborate? Surely it’s pretty much the same build cost with the exception cases requiring boring. Need to do the bottom end anyway for the bigger 4 3/8 flywheels…
  #32
Old 11-24-2023, 01:22 PM
harpwrench's Avatar
harpwrench
harpwrench is online now
I have a 117 in one bike and a 110 in another bike which was a 107 until this fall. The smaller engine is quieter, cooler and very responsive. For running around back roads 50-70 mph the 107-110 feels just as good to me. If it blows up I’ll be able to get it back together cheaper and faster than the 117 if it blows up.
  #33
Old 11-24-2023, 01:33 PM
pawhite's Avatar
pawhite
pawhite is offline
Thanks for your honesty! I am still in the drawing room for this build so hearing other’s honest feedback and experiences is always welcome. 👍
  #34
Old 11-24-2023, 02:26 PM
scott7d's Avatar
scott7d
scott7d is offline
I've had several different builds from mild to wild. This build didn't make the biggest peak numbers, but it was my favorite combination because of the broad torque and how the bike felt in general at the throttle. Peak numbers on the dyno sheet don't always tell the full story.
This was my old 113" build using the CR575's. Obviously exhaust and other components play a factor. But at 10:1 compression, it would be a good match for the CR575. If I recall correctly, I was running 10.2:1. It made a freakin' torque tabletop.
I've also used the CR595 and CR630i in a 117 and 124 build. But those would not be a good fit at 10:1 compression. I'd wanna be up around 11:1 for either one of those.
  #35
Old 11-24-2023, 02:32 PM
djl's Avatar
djl
djl is online now
Received 2,227 Likes on 1,611 Posts
Originally Posted by pawhite
This is my latest one, No Tq in this one as the dyno guy had some issues with leads on the day?? but he assured me it was 108.69.
Not sure what to make of this one; nothing attached; reply seems unrelated to the post WRT the heads.
  #36
Old 11-24-2023, 02:43 PM
djl's Avatar
djl
djl is online now
I tend to agree with harpwrench but getting to 107" a different way; think about an all bore 107. Case boring is required for the 4.125" cylinders and the crank should be trued and balanced which is cheaper than a new 4.375" crank. An all bore 107" motor is pretty torquey and they spool up fast. Not many here run them but a couple have; Max is runnng one now and I think he likes it. I think the S&S 585 could work as well at your current throttle body. Worth a look? JMHO
  #37
Old 11-24-2023, 03:40 PM
pawhite's Avatar
pawhite
pawhite is offline
You asked for a couple pics of the bike, can you not see two pics of the bike and one dyno? I can see them…
  #38
Old 11-24-2023, 04:03 PM
pawhite's Avatar
pawhite
pawhite is offline
Sounds very interesting. I will have a look. What sort of figures would one expect on this setup?
  #39
Old 11-24-2023, 11:42 PM
djl's Avatar
djl
djl is online now
Are you referring to expected dyno numbers?
  #40
Old 11-25-2023, 07:47 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
Not much difference in numbers either way tho an all bore will tend to rev easier/faster and make a little more hp. The stroker a little more early torque. One way to get a stroker to rev more like an all bore tho is shed 6+ lbs. of weight at the end of the crank by putting a solid primary sprocket on in place of the boat anchor of a compensator. Partly why I do 127hp/126torque in a stroker when most struggle to hit 120hp. That and the right combination of parts, head work and valve sizes to compliment those parts, and a good tune.
Very few 107s see 130/130. I've seen one max effort do it. A few strokers will break 130 torque but struggle to break 120 hp.
​​​​​​One thing to note is my 127hp is before 5800rpm.
In your case, I would do an all bore. Easier to break 120hp. I would expect low to mid 120s. 125 squared or there about would be a good all bore build.
Quick Reply: Mild 117 build cam
