2002 harley fat boy
I get none. That's because my DIY Breather goes up, not down, NO CATCH CAN. Gotta use some common sense. Air (crankcase pressure) is lighter than oil (crankcase air & oil mix) makes the vapor that comes out. My crankcase air goes out over the engine, under the tank & seat and drops down at the swingarm. No oil puking only crankcase air. Oil seep back down to crancase. Reroute you breather system and ditch the can.
robb1178 (11-09-2023)
There should not really be a need for any catch can at all. I run the hollow breather bolts with tiny mesh filters inside, straight to the atmosphere. There is a light oil mist on the nearby parts that I wipe off maybe once a month.
Excessive amounts of oil from the breathers is an indication something is not right with the engine I believe.
ve.
ve.
2002 Harley fat boy
I get hardly any oil in my catch can. Just a tiny bit of oil but a lot of water (1 to 1 1/2 ounces on start up and none after I ride about 20 miles) The question I asked was how much WATER does every one get? I am trying to see if I need to replace the breathers but because I get just a bit of oil I dont know if I need to change them. I am just concerned about the amount of water I get. So again I ask how much Water does every one get?
