Lifters for 650 high lift valve springs?
I have a 2010 Street glide stage 2 heads with Fuelling HP+ camplate, oil pump, lifters. The HP+ lifters are rated just above the spring rate of the AV&V 650 lift springs and even Fuelling suggested going with their race series lifters.I am wondering about these hyllift Johnson 2313 SE from Larry's Machining? Are these good lifters? How do they compare to S&S premium and Fuelling Race series lifters? I have read some online threads about some not good copies of these lifters. How can I tell if they are the good ones? Apparently Fuelling lifters are made by
https://Johnson lifters. Com
Johnson lifters like Fueling race series
2313SE | Larry Yacko
This is our best lifter. slow leak down w/pin oiling to handle the aggressive cam loads & higher spring pressures associated with performance cams used in high HP builds.
larrysmcymachineinc.square.site
The following 2 users liked this post by pgreer:
djl (10-18-2023),
TexasScooterTrash (10-17-2023)
djl (10-18-2023)
Remember, there are two “Johnson” lifter manufacturers. The one the OP linked is not Johnson Hylift (top line) which I believe is the one most parts companies contract to make lifters for them…
http://www.hyliftjohnson.com
pgreer (10-23-2023)
