Tick tock
The following 2 users liked this post by Max Headflow:
Harley1004 (10-05-2023),
Mchad (10-05-2023)
Just Getting you back for
Not sure how I did that.
I will say that I find the 9B quiet tolerable. Motor runs strong and don't hear any valvetrain noise at anything above idle. The single number woods cams above 0.580 lift are known to be noisey. Had an W8 that was horrendous. I suspect I could get it to work reasonable now. Both the W8 and this W9B were circa 2003. Don't know if Bobby softened the ramps as time went on.
My 17RK has had a slight single tick at 2000 miles. It has 53000 on it now. Only happens when hot. Don't hear at anything above idle..
What did I ever do to you that justifies you tormenting me with that video? Huh?
Mchad (10-06-2023)
Evo is a different animal.. It has larger rollers on the lifters. Both TC and evo wood Wx cams were ground on tracing grinders using the same lobe profile so it is not a good comparison.
