Twin Cam Motors Twin Cam 1998 thru 2017
Umbrella valve upgrade - w/ so many options, how do you pick
Old 08-19-2023, 06:07 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,016 Likes on 4,064 Posts
Oh they do, not too hard to see and you got problems if they don't. Did you pull the plugs?
Old 08-19-2023, 06:18 PM
07UltraGuy's Avatar
07UltraGuy
07UltraGuy is offline
Received 6,203 Likes on 2,239 Posts
Yes, the plugs are/were out.
I’m guessing clutch slip is the root cause.
Looks like I’m draining & removing he primary cover.
Not THAT big of a deal, as I have a new cover to put on anyway, but I wasn’t planning to pull that until I had the new fairing on and clutch cable run.
Everything wants to be done first. 😂
Old 08-19-2023, 06:20 PM
Max Headflow
If you can slip the clutch by pulling on the rear wheel while in 6th gear, I wanna see your biceps.
The following 3 users liked this post by Max Headflow:
07UltraGuy (08-19-2023), 98hotrodfatboy (08-19-2023), koko3052 (05-22-2024)
Old 08-19-2023, 11:18 PM
07UltraGuy's Avatar
07UltraGuy
I’m not sure what the issue was/is, but in order to activate the rockers/valves, I had to pull the rear footboard, left exhaust, and primary cover to turn the motor over w/ the crank bolt.
Ill deal with that after I get it back together and running.
Old 08-20-2023, 03:38 AM
buell95's Avatar
buell95
buell95 is offline
Is your drive belt loose and just slipping? Teeth on the pulleys look ok?
Something should of moved.
Old 08-20-2023, 10:16 AM
07UltraGuy's Avatar
07UltraGuy
Agreed.
The belt appears to be good.
I’ll throw the stock pivot arm back in it and see if that has any impact. It shouldn’t, but I don’t understand what the hell is going on yet.
Scootertrash60
EVO
14
03-04-2019 04:02 PM
Jim Hunchuk
Knuckle Head
09-27-2018 02:54 AM
SnoRider
08-22-2016 07:45 AM
VASportster
06-23-2011 09:11 PM
05 Wd Gld
05-20-2007 01:23 AM
Quick Reply: Umbrella valve upgrade - w/ so many options, how do you pick
