5th Gear oil seal removal HELP!!!!
Keep mangling it. Look closely at the one I removed. It eventually will pop out. You do need one with a good 90 degree bend to hook the steel part of the seal..
Not sure how you get a screw into the steel on this... The flat part of sheet metal in the seal is only about 1/16" wide..
I never did anything like this before and it seemed easy enough. I was starting to think I was some kind of gasket seal Savant but now I am humbled. 😆
You need to do the mod to a better screwdriver. Grab it with a pair of vise grips and while pulling things tight tap on the vise grips with a small hammer. The one with that has the paint on it looks to be the better of the 2. The chrome one looks like a really cheap screw driver. Grind off the end a little and try again..
The ones I used are Excelite, Craftsman and Great Neck..
I am in the process of modifying my slide hammer to hold vise grips .. me simply just pulling on it is not going to happen.
I believe you. I just dont have a screw thin enough.. What size screw did you use .. Im thinking no bigger than a #2
