rocker arm support torque specs
Hello All, I was recently replacing my rocker box gasket and over torqued one of the bolts in the support plate. I tore out any threads the bolt had contact with.
There was about 1/2 of thread left in the hole. I tapped it out, cleaned it up and got all the debris out. I went with a 1/2 longer bolt and it torqued to spec.
Would you trust it or do you think I should pull it ?
Hello All, I was recently replacing my rocker box gasket and over torqued one of the bolts. I tore out any threads the bolt had contact with.
acanlord (05-12-2023)
