Is the Wood TW-555-6R's base circle .020" smaller?
I was wondering if anybody knew if the Wood TW-555-6R conversion cams have the .020" smaller lobe base circle like the standard TW-555's? Andrews Products makes the cams for Wood Performance and I see that the Andrews conversion cams use a stock lobe base circle. Thank you.
Harley1004 (05-12-2023)
