Balancer is toast
#51
#53
#55
Comp nut on my 02 came loose; shaved .030" off. '05 didn't loosen up but I pulled it off and pre-emptively shaved off .030". I forgot about the torque procedure change. '05 is 150-165 ft.lb; when did it change? IIRC, the torque spec changed but a 45* additional turn was added.
#56
Engine compensating sprocket nut. 75 ft-lbs, then 45° to 50°
I still torque them to 150.. But I've not owned any 5 speed TC motors with rollers on the left side..
DId your 02 have a washer under the nut? Did you measure for nut bottoming or just cut?
BTW, my 02 RKC didn't have any issues as far as the nut coming loose...
#57
Although comp nut coming loose didn't happen to you and many others, it was an issue. Which is why the MoCo offered three different shim thiknesses to address the issue and why so many DIYers shaved .030" off the comp nut. Removing .030" was not a surgical operation; could be done carefully done on a bench grinder although if a lathe was available, a better way.
As for the shims, what I am familar with is the different sizes because in that era they had different size rotors, which required different shims.
I have heard of this happening. But again just asking if any work was done. Just curious is all.
#58
There was a service bulletin that came out early on. Can't find it.. This is out of the 06 manual.
#59
2003 motors were known to blow the left bearing if the motor was pumped above 100 hp/tq. New TQ procedure seemed to help.. @rigidthumper seemed to find this when he worked at a dealer.
rigidthumper (06-09-2023)
#60
2003 first year without Timken bearing. Back in the day, we considered a big deal. my 2007, I have not decided what to do with it. Do I do a conversion, or just re-ring or ..010 over? One of these days I am going to take it apart. Could bore to 103. But I just don't know if I trust it without doing a timken conversion.
