88 cam swap
The "ticking" is pretty subjective depending on the sensitivity of the listener but having listened to many stock and modified Harley vtwins, I have to say no; all twin cams do not tick. Rocker Lockers are desinged to solve a specific problem which is not valve train lash but is the rocker shaft bolts rotating in the support plate boss. To to the Rocker Locker website to undersstand the problem and then check your rocker shaft bolts for witness marks of the rotation; no marks, no Rocker Lockers but if the marks are there, Rocker Lockers will solve that problem.
I really don't see anything wrong with going to a 95 ci motor. IIRC the HD cast pistons are a bit cheaper than 98 ci as the 98s are typically forged. Don't know if you can still get the SE pistons tho..
BTW WFO larry can get you good KB forged pistons 0.040 over 95 for a good price. You can get them along with the new lifters.. Not sure KB is doing 98s yet..
Have a look around my website, explains a lot about my extensive research into the top end tapping problem, and the world's only PATENTED solution. Don't be fooled by imitations
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Technically it's the rocker shaft hitting the rocker tower bolts..I really don't see anything wrong with going to a 95 ci motor. IIRC the HD cast pistons are a bit cheaper than 98 ci as the 98s are typically forged. Don't know if you can still get the SE pistons tho..BTW WFO larry can get you good KB forged pistons 0.040 over 95 for a good price. You can get them along with the new lifters.. Not sure KB is doing 98s yet..
I don't see anything wrong with a 95" motor but why, when an extra 3" is almost free? CP has a variety of pistons for the 98" configuration; flat top and domed.
I first did 98" nikal sil. Would not do it again. After 50k it had scaring, and the cost to replate is about the cost of new. So I bored orginally over to 95". When they get worn it will be cheap to bore.010 over. I did it over the winter, so if there is a diffrence, I can't tell. Maybe it I drove them back to back.
IMO bore 88, to whatever you choose, is a great option. Non epa has more power than many factory bikes. 95" is tried and true.
Its cheaper to bore stock too.
"Cheaper to bore stock"? What does that mean?
No disrespect intended and I agree that the OP can make his own choice but I just don't see any downside to bore to 98 as you seem to. JMHO.
So no outer cam bearings on my dyna just inners? So if the 98 is just as reliable and proven as the 95 with more hp I might as well just go that route then. I read a bunch about the 95 being best bang for the buck so thats why I originally wanted to go that route. I definitely will look further into the rocker lockers and check out that website
lightweight bob (04-23-2023)
I didn't want to bore over 95". Though I realize people do it now, and as acceptable, I guess.
