110" Dyna Woods Triple 8's...
I see a slight timing mark on that plug too. I wouldn't worry about it. You could drop a few as suggested and see if that moves.
The clutch spring wasn't enough with the stock discs. The E1 discs I used have twice the friction surface.
I do have a perfectly good stock set of discs/plates if you want them tho.
The only downside I know of to the aim setup is a harder pull at high rpms. It's mostly why djl runs a pingle with it for speed shifting. You definitely don't want to run the aim with the SE spring I wouldn't think.
I run open loop as well btw.
Those plugs look great! If anything the front is a tad rich at idle. Leave it be.
98hotrodfatboy (03-19-2023)
The rear actually requires less fuel "because" it runs hotter.
As far as afr, the rear plug looks better to me, but because it runs hotter, it may be cleaning off better, the front ring looks black, both cylinders may be running the same afr.
I'm surprised you didn't set up the WEGO, one cylinder at a time.
With TT logs, I can see how close things are by looking at VE vs New VE, Lamba vs set Lamda, CLI and AFF, I peeked at the plugs once I think.
The following 2 users liked this post by 98hotrodfatboy:
Rusty Springs (03-19-2023),
Schex (03-19-2023)
Yeah I ran mine with the primary cover off when I did the 30 tooth solid sprocket and new shorter chain it comes with. I have a video of it somewhere here. I thought it was tight too but I haven't any issues/wear at all with the stock tensioner.
Talk about throwing you back off the seat. Try that torque with a 30 tooth! Hang on!
Ask djl his thoughts on the aim too. I just remember him telling me that because I was going to run it myself. Probably would've and done the pingle too but I was already over $5000 on this thing. Closer to $6000 probably. But I did an S&S crank, the DT 3 stage pump and plate, even my reed valves for crankcase venting were $200.
Anyone have experience with this?
https://www.dynojet.com/quickshifter...nectors-4-136/
https://www.dynojet.com/quickshifter...nectors-4-134/
I think I like It,,, if it works @ wot
Pretty sure Baker Drivetrain makes one as well... I was considering it at one time cause I thought theirs was better...
Need a Little help with the tune.. In the pic of the plugs the right plug is the rear cylinder.. I've been slowly making ground on the tune.. The rear cylinder at one point was pretty lean but had come along nicely except that for some reason I can't get a timing mark on the ground strap like the front plug.. Is it possible the coil is an issue?? Open to suggestions.. Thanks..
Does your bike have BCM? If so you should have a clutch switch and not only does it let you start the bike in gear but it also kills the injector pulse width when pulled for shifting to the next gear.. I found that in my Data logs.. So as far as I know, you don't need one.. I have a hard time remembering the proper system name.. It's the system where all the lights and switches are controlled.. Another "Brain Fart".... My 2013 was the first year for the Street Bob model.
What they call the Baker, saw adds before but can't find it
I couldn't tell if it was oil or or fuel in the pic but it does look shiny like oil.
This is the pingle shifter.
