Twin Cam Motors Twin Cam 1998 thru 2017
Crank Run Out...
Old 02-27-2023, 08:55 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,467 Likes on 3,643 Posts
Originally Posted by 60Gunner
Compression will help carry out the top end too. Don't be afraid of going 210 with a good tune. I run 212psi with no issues. CP's 3cc and 85cc chambers put me at 205 with the 590s. I asked Don what he felt comfortable with and like he said. Compression is nothing to fear. Anything will ping if you lug it. F'k it take it to 210 I said and ended up where it is.
I really do want to see where you end up with that exhaust. I have the same thing sitting here yet and love the sound. I like the Pro Streets too tho.
If should be a minimum of 216 psi.
  #52
Old 02-27-2023, 09:11 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
A little OT... What about his M8 cams?
The 777XE stands out as a bolt in on the 114 imo. That is a dream torque curve.
From FM Cam shootout...
The WM8-777XE is somewhat unique among this group as it was designed as max effort bolt-in. This pattern is quite a bit different than the others. The 777XE made the most horsepower by a pretty wide margin, but it also made the least amount of peak torque. The curve is also the flattest & smoothest of the test. Low RPM’s are still surprisingly stronger than several of the others, but this combo loves RPM’s.
  #53
Old 02-27-2023, 09:31 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
I said I wanted to be around 210. Ended up a little higher.
  #54
Old 02-27-2023, 09:55 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,017 Likes on 4,064 Posts
So it took him the WM8-222 to the WM8-22X to the WM8-22XE?
Same progress for the WM8-777?
How many did it take for the W8 cams?
  #55
Old 02-27-2023, 09:56 PM
Max Headflow
You need to stop buy your compression gauges from Amazon.. Too Woke..
  #56
Old 02-28-2023, 03:53 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
That is from NAPA .It has been verified.
Good crankcase venting and better ring seal will do that. You should try it some time. Reed valves are far superior. I don't need to pull my tank and rocker covers if they do go bad either.
  #57
Old 02-28-2023, 03:55 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
I don't get the question. Put the pipe down Max.
  #58
Old 02-28-2023, 08:08 AM
Max Headflow
I wouldn't expect you to..
  #59
Old 02-28-2023, 08:22 AM
98hotrodfatboy
Maybe he got it right the first time...
  #60
Old 02-28-2023, 09:36 AM
Max Headflow
On the W8,, Yes.. BTW, The timing on that cam is real close to the timing on a Honda XR200.
Quick Reply: Crank Run Out...
