Crank Run Out...
#41
98hotrodfatboy (02-26-2023)
#42
I just need to figure out the exact direction with Pistons.. Money is an issue.. I was terminated from my job on November 3rd but through my Union I was able to get back to work 2 weeks ago.. lost $28k in pay..
#43
A flat top at 110” would get you 10.6/7ish. Thats the 888 sweet spot, I think most kits come flat tops and would like to know who has a domed option. To push past 11:1 would open up other cams too, maybe, dare I say it………the cam that just can’t be overlooked in these situations. For those that don’t cry (over a little noise) and whine like little babies begging for the bittie………… the cam with the single digit designation, the 8!?
98hotrodfatboy (02-27-2023)
#44
#45
Bobby’s 888 is based directly on his original W8 Evo grind that originated in the 90’s (and later the TW8 & TW8-6). I asked him for a specific revision about 10 years ago for use with stock valve springs and less aggressive ramps; he took the TW8-6 changed the lobe centers to 100 degrees, changed lift to .575 and created the 888. I still have the original test cam in my library, it’s a fantastic grind
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#46
fuelmoto (02-27-2023)
#47
98hotrodfatboy (03-04-2023)
#48
I have to agree about the W8 grind.. Several years ago I spoke with Bob Wood about changing the opening and closing to numbers that I thought would would satisfy lower compressions.. It was for my 96"Evo that I was running a 9b in and that can I felt out performed the 9b. He labeled it a W6EXP.. It hi earlier than the 9b and carried just as far.. still have it.. the first sheet is the W6EXP and the second is the 9b.. All I'll say it's the W6EXP had an LSA of 103..
#49
Those charts are very nice examples 👍, I also really like the 9B in a big Twin Cam with enough cylinder head to support it, a tick more compression and the 9F really lights up even more. I’ve always enjoyed Bob’s uncanny ability to adapt his cam patterns over different platforms
#50
I really do want to see where you end up with that exhaust. I have the same thing sitting here yet and love the sound. I like the Pro Streets too tho.
