Crank Run Out...
#91
#92
98hotrodfatboy (03-03-2023)
#93
#94
I would go with their 600 or 660 in a build like mine tho.
I think that 570 might work well in an otherwise stock stage 2 103 or something.
I know they do twin cams with their cams.
Their main thing is the sporty and their 1275.builds are capable of 120hp. They are all about hp not stump pullers.
I'm looking to beat djl's 98 build with this Night Train. Picked his brain a little this morning. It will be interesting to see where it ends up.
If this guy is willing to write me a blank check so to speak, and he pretty much is,.115hp.is definitely doable.
Don D. being out of the game for now kind of threw a wrench in my plans but I think I have a good replacement in mind to get it done.
djl (03-03-2023)
#95
They have done 107 builds with that 570 actually.
What happened to Don?
#96
Don is off on assignment for at least 6 months...Boeing special project.
Probably give Larry a call. I need lifters too so I'll see what he has going.
#97
#98
That 570 is not a big hp cam but designed to add power up there without losing in the bottom.
They are all very exhaust sensitive but those Rush mufflers you are running do very well with cams like that. Better than any I have seen. And they map in real easy.
#99
i posted one with the 570s in a 107 build 3 or 4 years ago. I don't think i have it anymore and I'm too lazy to call them and ask them to send me some.
It's good that don is OK..
I feel sorry for Larry..
The following 2 users liked this post by Max Headflow:
djl (03-03-2023),
Lonewolf176 (03-03-2023)
#100
Have you seen a Hammer 660? They will make power past 7000rpm.
