No muss no fuss filter change
Just hard riding..
That was with my Woods W8 build..83" Evo. 96/96.. Just goes to show what using the power you create can do.. The crank pin was the weakest link.. BUT THE FILTER DID IT'S JOB ... YES FRAM..!!!
rocketnorton (03-04-2023)
Like many, I used a cereal box/12 pack pop type cardboard too..UNTIL someone in the oil forum shared his tip.
an "articulated" cardboard funnel comes with every filter.
No more rootin' around in the recycle bin for cardboard
the other tip I learned here that helped minimize mess, is punching a hole in the filter
..L.T.A.
..L.T.A.
Old Sport (03-02-2023)
Yeah they are kinda cool until the bracket breaks... Then it drags on the ground until it wears a hole in the filter.. Tucked it up so it could be loaded on the tow truck.. Had to dodge the oil while trying to get ahead of Butch to get him to pull over..
Old Sport (03-05-2023)
Plus doesn't have it out front actually help to cool the oil a little, I'm sure it's not a lot but it's got to do something..
Don't pat yourself on the back too hard..
I liked it enough to make the same mod to my softail and also had to modify and re-fab Dan's bracket. If I lose it on the highway some day, I will post pictures; I do have roadside assistance.:icon-wink:
98hotrodfatboy (03-04-2023)
Max, surely you don't think that I didn't think of that possibility? Thw bracket that came with the "kit" did not fit my '05 FLHT, too old and I knew the bracket would require some re-fabrication to fit. I cut, modified and welded so it would fit; I would never say never but don't think it's going to break. Where were you and 98HRFB when I posted? That was the only reason I brought it up again; just thought it odd that the post didn't draw comments, maybe even some snarky ones; oooops, I guess it did. As for cost. necessity, etc. I think I am in good company in that regard.
Max Headflow
Milwaukee Eight (M8)
26
04-30-2022 06:47 PM
