Hard start when warm
Originally Posted by gloucesterman
I believe I did load test it. Didn’t I? Drops to 9.4 volts under load?
I will say though after my ride and during it I shut the bike off on 3 occasions and it started right up. I can’t believe that small knick and cleaning the starter terminals would make all the difference in the world but it seems to be much better. Still I will load test the battery if my procedure was incorrect. I have a clamp meter. Could you walk me through your procedure?
Sounds like cleaning the connections did the trick though.
The following 2 users liked this post by roussfam:
gloucesterman (02-20-2023),
HarleyHappy (02-21-2023)
When you are it, check for a voltage drop over the positive cable from battery to solenoid and solenoid to starter. If you have any voltage drop, even like 1/10 of a volt, from one end of the cable to the other, suspect that the cable has corrosion inside and you can't see it. When that cable comes under load for the starter it can cause the large voltage drop you are seeing.
Ideally the battery should stay above 11 Volts when cranking, and anything lower on a FI bike and the fuel pump won't run. Anything in the 9 range is not good news.
