Cams
Cams
Greetings!, I had a 2004 R/K that I added Andrews26g cams and V&H 2/1 pipe and it ran well . Now I just purchased a stock 2005 RK and plan to changes cams when I go into camchest an check the crank. Is there is a big difference between the Andrews 26 and the S&S 510 cams. On paper they look close when comparing the numbers. This 2005 bike will stay an 88 for a while, is carburated and will be getting a Bassani 2/1. I know this is old equipment but its what I have at this time andI like the older bikes. Any experiances with the S&S 510 cams, I would appreciate. . Thanks!
My desire was to eliminate the tensioners, the cleaner running at mid to high was a plus
I didn`t notice any loss in low end but then again neither myself nor passenger are "large"
That said I ran them in a stock carbed 88" with a 2-1 pipe for 15K miles and liked them
Took them out when I upgraded to 98" and replaced with 570G
Mikey 1450 (02-20-2023)
