Twin Cam Motors Twin Cam 1998 thru 2017
HSR 42 or 45?
Old 01-23-2023, 12:27 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,016 Likes on 4,064 Posts
Originally Posted by SwedishMeatball
Thanks for your reply. I don't know any flow numbers for these heads, they have 1.940" intake valve, and the intake port is 45 mm where it meets the manifold, compared to 42 mm for my stock heads.
I have a matching S&S manifold that is 45 mm where it meets the head and around 51 mm at the carb side. I can fit both 42 and 45 mm carbs using different rubber seals.
45mm is like 1.77".. You can pretty much use a G manifold or an HSR45 from Ultima or SnS. Make sure to check the port size so it matches.. Google shows up a bunch of ones..
Old 01-23-2023, 01:01 PM
SwedishMeatball's Avatar
SwedishMeatball
SwedishMeatball is offline
I think it is a G manifold but with the mounting flange machined down to a circular flange like on the stock manifold, but bigger.
Manifold and ports are the same size and they match very nicely.
Max Headflow (01-23-2023)
Old 01-23-2023, 01:40 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
If you're interested I have a dealer kit of jets, needles and the next size bigger needle jet. Forget the number off hand and I'm at work. The needle jet isn't isn't all that readily available. A few different accelerator pump nozzles too.
Fits the 42 or 45.
I would go with the 45 in this case.
Old 01-24-2023, 02:39 AM
SwedishMeatball
Fits the 42 or 45.
Let's see, I have not bought the carburetor yet. But thanks for your offer.
Old 01-24-2023, 03:24 AM
SwedishMeatball
I found what is supposed to be the flow numbers for my S&S heads, does it make any sense?
Old 01-24-2023, 07:42 AM
MattLS6's Avatar
MattLS6
MattLS6 is offline
What would the drawbacks be? The heads should flow more.. I doubt they will flow more than 300cfm at 28 tho..
The flow here is at 10 inches of carbs on different manifolds. Multiply by 1.67 ro get the flow at 28..
This is good stuff, thanks for sharing. The data doesn’t lie, I can see why 45 now given the projected head flow.
SwedishMeatball
Twin Cam Motors
20
10-06-2022 02:06 PM
SwedishMeatball
Twin Cam Motors
14
09-21-2022 10:43 AM
SwedishMeatball
Twin Cam Motors
09-08-2022 12:18 PM
carguy1959
10-04-2020 06:36 AM
Tubz
08-21-2008 07:55 AM
Quick Reply: HSR 42 or 45?
