Twin Cam Motors Twin Cam 1998 thru 2017
Is it Absolutely necessary to run Synthetic..
Old 11-04-2022, 06:54 PM
MattLS6's Avatar
MattLS6
MattLS6 is offline
IMO as long as there’s oil in it, it’s the right viscosity, and it’s changed on an appropriate interval, it doesn’t matter…
My Ironheads get VR1 conventional, my newer Harleys get VR1 synthetic. I run conventional during engine break in on all bikes. It all does the job. Twin cams are hot SOBs, if they happen to run cooler on synthetic seems worth a couple extra bucks to me. Whether they do or not I dunno, however.
Old 11-04-2022, 06:55 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,466 Likes on 3,643 Posts
One thing I do know for a fact and many have said that when it actually comes to breaking in a motor, a fresh build, Dino oil is the best for breaking in.. I've been told that by some of the top builders I know. Then after that you want to use what you want that's fine..
The following 3 users liked this post by 98hotrodfatboy:
brakeless (11-04-2022), djl (11-05-2022), Uncle Larry (11-04-2022)
Old 11-04-2022, 07:40 PM
Y2K's Avatar
Y2K
Y2K is offline
Received 3,298 Likes on 1,407 Posts
Only thing with dino is you'll have to change it twice as often especially if you run in high heat areas like AZ.
Old 11-04-2022, 07:52 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is online now
Received 6,259 Likes on 3,414 Posts
WTF? 60Gunner hasn't been in here spreading his wisdom, yet? Give it time...
The following 2 users liked this post by NorthWestern:
eighteight (11-07-2022), Tired (11-04-2022)
Old 11-04-2022, 09:05 PM
98hotrodfatboy
No matter what the oil in my bikes I never go over 3k.. My hot rod Evo is 2500 miles..
Old 11-04-2022, 09:52 PM
Y2K's Avatar
Y2K
Y2K is offline
Well might as well run dino then,I run Amsoil and change at 5000 miles. (my indy is an Amsoil guy)
I run Mobile 1 in my Camaro SS and same at 5000 miles.
Old 11-05-2022, 05:11 AM
sonny4's Avatar
sonny4
sonny4 is offline
With syn you could very easily go 10,000 miles. I change mine at 5,000.
The following 2 users liked this post by sonny4:
Street Glider Rider (11-11-2022), Y2K (11-05-2022)
Old 11-05-2022, 07:24 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,363 Likes on 5,501 Posts
Originally Posted by Hammerhead Pat
I ran Mobil synthetic in my 2011 twinkie for the first 40k miles and then switched to dino , it hasn.t imploded yet...
But if you change to SNY it will leak oil all over town. That was another myth.
Uncle Larry (11-05-2022)
Old 11-05-2022, 07:35 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,256 Likes on 4,783 Posts
Answering the original question.
Nope.
WONKEY (11-05-2022)
Old 11-05-2022, 08:22 AM
orbit's Avatar
orbit
orbit is offline
From Bob is the Oil Guy...
https://bobistheoilguy.com/motor-oil-104/
I'm running Schaeffer's 707 V-Twin 20W50 in my Twin Cam.
Top end was freshened a year ago.
Engine builder said to break it in with VR1, which I did, and that if I wanted to run synthetic, fine, but put at least 2K miles on the motor before doing so.
Did that as well.
He recommended running shortened oil change intervals no matter which type of oil I decided to use.
Oil is cheap.
New motors ain't...
As far as I can tell, oil temps have dropped slightly.
YRMV.
Quick Reply: Is it Absolutely necessary to run Synthetic..
