Twin Cam Motors Twin Cam 1998 thru 2017
Twin Cam base O-ring leak
Old 09-18-2022, 07:56 PM
Smar84's Avatar
Smar84
Smar84 is offline
Default Twin Cam base O-ring leak
Hello, I just recently purchased a 2008 Street glide with 35k miles and noticed a leak in between the cylinders at the base. It’s not bad, but it’s seeping. When I went for a ride this afternoon I checked it again and I could see minor bubbling from the front cylinder. My question is do I need to address this right away or monitor it and check my oil. Like I said it was minor seeping but I’ve never had a twin cam that’s done this. Thanks for any input
Old 09-18-2022, 08:08 PM
2500hdon37s's Avatar
2500hdon37s
2500hdon37s is offline
Received 1,586 Likes on 683 Posts
If you're seeing bubbling while the bike is running I would get that addressed ASAP.
If it were just a weep/ getting the engine's finish wet and oily-grimey, I could understand running it. But to see bubbling coming from base of a cylinder could mean a loose or broken cylinder/ head bolt. Not fixing that right away can and will lead to bigger, more expensive fixes.
Rollbar (09-19-2022)
Old 09-18-2022, 08:21 PM
Smar84's Avatar
Smar84
Smar84 is offline
I saw a very slight bubble no bigger then a pin ***** when I shut it off right in the middle between both cylinders. And slight wetness on the upper case bolt cause it must have ran down. I just put synthetic oil in it as well which probably didn’t help if it already had this issue
Old 09-18-2022, 08:23 PM
Smar84's Avatar
Smar84
Smar84 is offline
I’ve read you can clean up the area and use permatex windshield sealant to stop it… but idk if I’m willing to try that.
Old 09-18-2022, 08:24 PM
Smar84's Avatar
Smar84
Smar84 is offline
There is also not allot of info on stock twin cams with this problem, I’ve had several bikes, all twin cams and never had a leak at the base so idk.
Old 09-18-2022, 08:31 PM
Stinger1's Avatar
Stinger1
Stinger1 is offline
Well, it's not going to get better only worse.
A year ago I had just a very slight base leak, I pulled her into my garage and began tearing her apart. 2 days later all fixed and it wasn't a bad job.
Don't put things off, things only get worse over time. DON'T use band aid fixes.
Fxd_king (11-07-2022)
Old 09-18-2022, 08:33 PM
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
Winter is on its way...
Old 09-18-2022, 08:35 PM
Smar84's Avatar
Smar84
Smar84 is offline
So it was a easy job? Did you have to disassemble the pistons as well? Not finding a lot of info. I do have a manual downloaded and have been reading it over. I know the basics just not sure if I want to tackle this.
Old 09-18-2022, 08:49 PM
QC's Avatar
QC
QC is offline
If you're at all mechanically inclined, it is not too difficult. Patience, attention to detail and just a couple special tools and your manual.
Old 09-18-2022, 09:35 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,016 Likes on 4,064 Posts
I've had a couple leak on performance motors with some miles one them 40-50K.. HD used to use Buna O rings on the cylinder base. Go to viton.. Also do the O rings for oil return in Viton..
Quick Reply: Twin Cam base O-ring leak
