Twin Cam base O-ring leak
Fxd_king (11-07-2022)
Did you re-torque the bolts that hold the two halves of the case together? There's one that runs right in the valley of the cylinders. I'd clean the entire motor really well and be 100 percent sure that that is where the leak is. While it's not a huge job it is still a job that requires some mechanical skills, tools and a factory service manual. First time in is a learning experience after that you pick up a few tricks that can make it easier. I would definitely wait for winter if you have winter...its a great time to think about adding a big bore or some cams.
Definitely plan on doing a big bore kit with cams, probably gonna wait till spring. The leak has not gotten any worse. I did check the torque on the top case bolt and it’s within spec. It seems to seep more when it’s just parked or cooling down after a ride. Either way it’s not that bad where I had to stop riding it. Problem I am having is finding a reputable Indy dealer to do the work. Or I may just get the Manual and try to repair it myself. Haven’t decided.
Rogue8Man (11-21-2022)
