Twin Cam Motors Twin Cam 1998 thru 2017
Screamin' Eagle High-Flow 58mm EFI Throttle Body 27200029
Old 09-11-2022 | 10:23 AM
djl's Avatar
djl
Originally Posted by Trigger-Man
Duhhhhhh LOL. That also means higher rpm's where I'm not getting the push I'm looking for.
Duhhhhhh LOL. It's not the rpms brother,it's the gearing. Try it.
The following 2 users liked this post by djl:
eighteight (09-22-2022), Trigger-Man (09-12-2022)
Old 09-11-2022 | 01:33 PM
PureHybrid's Avatar
PureHybrid
IMO the Se-585 cam is fine for a midrange cam. Open up the head pipe like others mentioned, I've never experimented with the power limit through a cat, but I'd guess it's north of where you are now. From here, I suggest getting the heads ported if you're looking for more
Trigger-Man (09-11-2022)
Old 09-11-2022 | 08:37 PM
ntraindavefl's Avatar
ntraindavefl
A CR575 and free flowing head pipe w muffler tunable disks would show power everywhere, maintaining noise control.
For guys out there like this who want roll on power but like stock style motors, like Arseman said, can’t have it all. Duhhh lol
The following 2 users liked this post by ntraindavefl:
djl (09-12-2022), Trigger-Man (09-12-2022)
Old 09-12-2022 | 11:28 AM
djl's Avatar
djl
I like the CR cams; running the CR595 in my latest 98" build; 115/115. However, regardless of cam and exhaust, crusing at 70mph in sixth gear and rolling on throttle to overtake is a mistake; drop a gear and wind her up and get around whatever is in front.JMHO.
Trigger-Man (09-13-2022)
Old 09-12-2022 | 03:30 PM
harpwrench's Avatar
harpwrench
A basically free and reversible mod: next time you need a rear tire use a cobra chrome 180/60R-16. It’s a little shorter and does the same thing as dropping a tooth on the trans pulley. Not a huge difference but it’s an improvement. You’ll need to use the PV to adjust the speedo a little. It’s a radial and you’ll notice a better ride quality. If you’re street tuning this yourself it’s not comparable to a professional tune by a talented tuning technician. Which can be a challenge because just having a dyno doesn’t mean they’re any good at tuning.
Old 09-13-2022 | 08:31 AM
Trigger-Man's Avatar
Trigger-Man
Appreciate everyone's input! Anyone aware of a good tuner in the Grand Junction (western Colorado) area?
Old 09-18-2022 | 11:57 PM
Traildale's Avatar
Traildale
Get rid of the cats. Tuning with cats installed is a cluster. The cats already get hot as fu#k with a stock tune. Adding more fuel with a tune and you are going to have problems.
Old 02-12-2023 | 08:06 PM
SteveDotWorld's Avatar
SteveDotWorld
Maybe see if your tune needs to be adjusted in the higher RPMs. You may be running out of fuel or timing up high. Just a thought. With stock heads you aren't going to gain much with the larger TB and injectors.
Old 02-13-2023 | 03:58 PM
Max Headflow's Avatar
Max Headflow
I would say they could. The CVO 110 heads flow about 275 cfm @28 stock.. They are not the same heads as a 103.
Old 02-15-2023 | 08:06 PM
60Gunner's Avatar
60Gunner
That's pretty good for stock heads. I know Don likes to work with them but I didn't know they flowed that well stock.
