06 88TC to 103 swap, what do I need?
Just about to pull my blown 88tc from my 2006 fxdli with 20k miles on motor and frame. Dropping in a 2014 fxdl 103 motor only with 3k miles on it.
Im currently planning on using my compensator from my 06 (trying to stay within a budget as much as reasonable), along with my stock throttle body, thundermax ECU, and my stock 6 speed tranny.
Upgrading my stator to a 09+, and upgrading the regulator to the same. Upgrading the front motor mount to a predator.
What should use for primary bearings? It looks like the 06 and the 14 are different part numbers, so which would work in my situation? If its highly suggested I upgrade the compensator, which years would work?
Any other parts I should change out while the whole things apart? Big fan of doing things right the first time around.
As far as the SE comp goes, I assume youre talking about the one compatible with 06-11? No issues with that fitting into a 14? And if I do that, still get the inner primary bearing that fits the 06 as well Id assume?
I know my way around an engine, but lack the knowledge with cross compatibility when it comes to twin cams.
Sorry if these are rookie questions, have spent hrs on forums trying to find the answers, to no avail.
Appreciate the info!
You need the 061 if you are still tuning the old alternator rotor. You can use the 64A if the alternator has been upgraded.. Don't need the adhesive kit. Use JB weld.
ShovelheadShamus
Engine Mechanical Topics
07-14-2022 09:09 PM
eds06roadglide
11-16-2010 08:51 AM
fatguyona1000
01-24-2010 12:26 PM
