TC88B to 96", bottom end?
#31
I can't remember the name of the baker rep that used to hang out in the drive section but he stated that one of the issues with the DD6 was that the clutch dogs were face cut at a 2 degree angle and the OD6 was at somewhere between 4 and 6 degrees. The more angle helps to hold the gear selection in gear. It can also make it a little harder to shift out of gear. With less angle on the face cut, banging the gears can round the dogs and can cause gear skip / bent shift forks.
#32
From the Baker website in the technical "details" for the DD6.
"The dog teeth are backcut at a 1° angle to optimize the smooth shift possible, while standard gearsets are cut to a 4° angle."
There is no similare information in the technical details for the OD6. Not sure of the reference to "standard gearsets"; reference to OEM or other Baker gearsets. Sounds like I should not be using the Pingle shifter with the DD6 though. The instant shift feels like " banging" the gears but with the ignition off for the shift, not the same as banging the gears with the foot shifter. Also, with the VPC, power shifting can be a challenge. I hardly ever use the Pingle but if some guy pulls up next to me at a light and wants to go; I will use it to my advantage.
Max Headflow (07-18-2022)
#33
Thats the plan. In for a pound, in for a tonne!
I’ve had this bike for 19 years and it’s bone stock.
I’m not selling unless I’m living under a bridge so I’m not opposed to spending on top to bottom quality, transmission and suspension upgrades will be done as well.
I’ve seen what quality suspension can do, and the Softail dream can get a bit squirrely with stick power.
Sounds like you are opting for a 107", 3.938 x 4.375. Your stock heads are approx 85cc. Flat top pistons will put you at approx 10.3 ish:1 with 30tho head gasket. Or 10.1 ish:1 with 0.040 gasket.
Any idea what cams you want to use that work well with this build? You should know what your cam options are before hard decision on compression. Early style 99-06 gear drive cams may limit choices some. Make sure valve springs handle the lift you end up with. Your stock springs won't. Don't put the cart before the horse
A lot goes into choosing the right cams for the job
#34
#35
mgmdvm
Fuel Moto / Jackpot Mufflers
08-18-2011 11:59 AM
