I started installing Evolution Industry’s compensator eliminator on my 2013 Breakout, and think I’ve got a spacing problem. The kit came with a spacer that’s supposed to work with my bike, but the sprocket and clutch assembly definitely aren’t aligned within spec (0.030”). Has anyone else encountered this issue? I’ll call Evolution tomorrow, but thought I’d pole the forum too in case they don’t respond.
I'm running A Vulcan Engineering compensator eliminator on my 2007 Dyna. Perfect alignment between the motor sprocket and the clutch shell . . . BEST $170 I spent on the Dyna. Personally, I took a pass on Evolution Industries They are overpriced.
My 30 tooth from Evolution Industries didn't come with or need a spacer for perfect alignment. Didn't think it was over priced either considering it came with a new chain and bolt/washer for install. Bob Woods recommended.
