Possible oil pressure issue
I noticed something a couple of days ago that has me questioning what might have been done to my bike by the previous owner. When riding home the other day, I noticed the oil pressure fluctuating and the pressure showing higher than it should be at idle. After it had cooled off I removed the sending unit and and installed a mechanical gauge. When started again, the pressure was showing 44-45 lbs. at idle. When revved to 2000 rpm the pressure was 60-62 lbs. Way too high according to the service manual and everything I have read on here. The previous owner changed out the gauges to Dakota Digital units. I did verify that the oil pressure gauge was set to work with the OEM sensor.
Upon re-installing the sending unit, the gauge fluctuated from 38-44 at idle, but dropped to 8-10 lbs at 2000 rpm. I figure the sending unit is bad. It is an OEM Harley unit. Still the high pressure that was showing on the mechanical gauge has me concerned. The oil temp when I ran the tests was 180-190 deg. There are no strange noises and no oil in the air cleaner. I'm thinking it may be time to crack into the engine and see what I find.
Some details about the bike.
2008 Ultra Classic 62K miles, Vance and Hines Hi Flow air cleaner, full Vance and Hines Exhaust & HP3 tuner. Not that it matters, but the previous owner added Screaming Eagle plugs and wires as well.That's it for modifications as far as I know. Thoughts, opinions, advice welcome. Thanks all.
06SGWA
01-30-2015 11:18 AM
