MM fi?
I dont think so. But I am no expert, my first HD was an 01 road glide I bought used with 60K and it ran fin till I wrecked it being stupid. And if you do have problems you can always do a carb conversion
prepper (07-13-2022)
I would pass. Why buy a bike with known EFI issues knowing parts and competent tuners are hard to find and a carb conversion may be in the future. A proper carb conversion will cost about $700-$800 so better to pay a bit more for the later EFI model IMHO; the Delphi EFI is so much better.
The following 2 users liked this post by djl:
98hotrodfatboy (07-02-2022),
Stiggy (07-14-2022)
I have an 01 Road King with 70k on it MM FI ( bought it new ) I have had zero problem with the FI system. Just finished 98 motor had it tuned with Techno Research tuner. The bike runs well. I will admit it is the unicorn of the bunch but wouldn’t trade it for anything. The police bike your looking at came with the 95 motor ( definitely nicer than the 88) if you like the way it runs that’s all that matters. I have been around fuel injection for 40 years, aside from the PCM there all basically similar as far as sensors and functionality. The Delphi with o2 definitely mixes better but I doubt you will feel the difference. My 98ci did 100 hp 110 torque gets low 40s mpg. I also have am 09 Road Glide 113ci with a Thundermax (wide band 02 sensors) gets about 40 mpg flat. They both run well.
p.s. the road glide has left me on the side of the road with no throttle response twice over the years 100k on that bike the Road King has never failed
good luck
good luck
thnx
jm
