11 disc clutch + Barnette spring question
Hi All,
Have a 2014 SGS w/ hydralic clutch stage II. Clutch slipped with the new cam so I tossed in an 11 disc barnette clutch and thier firm spring. Put in a man o war compensator and new primary tensioner while I was in there.
Issue is that twice when taking off at left turn red light (at the same intersection on two different rides no doublt) when the clutch engaged and we started to giddy-up the clutch let out a very breif squeal for just a fraction of a sec but did not do it the rest of the day. This was after short warm up and about 2 miles of modest riding so primary s/b fairly cold, 73 degree day. I am running redline in the primary. Bike rides and shifts fine with no slipping at all even of hot launches. Any thoughts on the noise befor I go back in to find out that "they all do that" . Sounded like dry discs for a split second but I soaked them prior to install. Have 250 miles on the cluch. MAybe one has a warp to it that only shows up when cold????
customsoftail200
05-20-2009 08:04 PM
