Twin Cam Motors Twin Cam 1998 thru 2017
Much love for the 96B engine ?
Old 06-03-2022, 04:49 AM
HeritageBrads's Avatar
HeritageBrads
HeritageBrads is offline
Default Much love for the 96B engine ?
As per my other post I'm back on a Harley (2010 Heritage softail) which uses a 96B engine.
How are folks finding those engines ? What have you all done to them or what needs doing to them ?
Cheers all.
Old 06-03-2022, 07:47 AM
Stamin Aman's Avatar
Stamin Aman
Stamin Aman is offline
5th Gear
I have a 2008 Heritage 96" and of all my 23 Harleys over the past 56 years in the saddle, she's been the most reliable so far.
Imported from North Carolina by her previous lover, I have a breather kit, V&A pipes which woke her up nicely, on top of whatever the last guy did.
We ride her long and fairly fast here in South Africa, never let us down.
The following 2 users liked this post by Stamin Aman:
HeritageBrads (06-03-2022), House O' Payne (06-06-2022)
Old 06-03-2022, 08:30 AM
K. Lindberg's Avatar
K. Lindberg
K. Lindberg is offline
I had a '09 FLSTC and only fault was the compensator starting to act up at
37 000 km/23 125 miles
Also had to clean the inside contacts of the ignition switch. Easy to fix and cost $0
One of the vulced bolt/rubber fasteners for the side luggage rack gave up and splitted. Was easy and cheap to fix.
Other than that it was great!
The motor had an SE aircleaner element and a SE exhaust. SE Race tuner (the orange box) fixed the lean running.
The following 2 users liked this post by K. Lindberg:
HeritageBrads (06-03-2022), Stamin Aman (06-06-2022)
Old 06-03-2022, 08:31 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
Needs cams for sure. Every stock Harley engine does. And a tuner. That's minimum..
Compensator is junk. They all are. I'd get rid of it.
The following 2 users liked this post by 60Gunner:
HeritageBrads (06-03-2022), LenBoyLo (06-03-2022)
Old 06-05-2022, 04:23 PM
HeritageBrads
I'd read a bit about the compensator but figured they were only an issue if the bike was ridden hard all the time ?
What cams are folk using in them ?
Old 06-05-2022, 05:06 PM
djl's Avatar
djl
djl is offline
Received 2,227 Likes on 1,611 Posts
If the OP has not paid the "Harley Tax" and completed the Stage I upgrade, i.e., intake and exhaust he needs to include that upgrade along with a cam. Any cam the OP chooses will need more than stock compression to perform. If I had to pick one bolt in cam, it would be the S&S 509 which should boost CCP near 185psi. As posted previously a fuel management system like the Powervision should be part of the plan along with a dyno tune once the upgrade is completed. The OP needs to love the 96B motor about $15000-$1800 worth, depending on parts selection and love to get his hands dirty as well.
HeritageBrads (06-06-2022)
Old 06-06-2022, 07:45 AM
ThePaintPirate's Avatar
ThePaintPirate
ThePaintPirate is offline
Received 1,558 Likes on 808 Posts
Just depends on how far down the rabbit hole you want to go. Got an Andrews 57H in my 96B, got enough power to be fun but nothing to write home about. Even stock it was much better than the earlier 88 CI.
Old 06-06-2022, 12:00 PM
djl's Avatar
djl
djl is offline
Originally Posted by djl
If the OP has not paid the "Harley Tax" and completed the Stage I upgrade, i.e., intake and exhaust he needs to include that upgrade along with a cam. Any cam the OP chooses will need more than stock compression to perform. If I had to pick one bolt in cam, it would be the S&S 509 which should boost CCP near 185psi. As posted previously a fuel management system like the Powervision should be part of the plan along with a dyno tune once the upgrade is completed. The OP needs to love the 96B motor about $1500-$1800 worth, depending on parts selection and love to get his hands dirty as well.
Too late to edit but need to correct a typo and add the purchase of the HD service manual would be wise.
Old 06-06-2022, 12:45 PM
sonny4's Avatar
sonny4
sonny4 is offline
I got about 120,000 miles on the same engine. Still ran before I took it apart for a rebuild. Agree with the above on the stock compensator. It is junk.
Old 06-06-2022, 03:39 PM
House O' Payne's Avatar
House O' Payne
House O' Payne is offline
Well, since I just bought a 2011 Crossbones, (96B motor) my 'ears' perked up with this thread topic!
Since the compensator was pointed out as 'junk' I did some quick research and learned it's possible to retrofit a much improved 2014 version into the older engines (back to 2010 according to this video):
There is also an aftermarket upgrade:
Gonna dig more into this and will post what I learn.......
Quick Reply: Much love for the 96B engine ?
