CCP increased after changing to larger cams?
Heads are 84cc. As stated by another person, I think I just need to run it first. I know everything is installed properly. I just thought I could check the CCP before starting just to see how much it dropped between cams. I'm gonna fire it up next weekend when I get home. Thanks.
RS cams are a bit lackluster to begin with and could use all the compression they can take. A friend is contemplating getting rid of these very same same cams in a bike he bought with them, Zippers kit I believe, so yeah I've seen them first hand and told him the same thing. They'd be fine with a bit more compression than the typical 185 most seem to think is a good target compression. I wouldn't run them at less than 200.
JamesH (06-01-2022)
The following 2 users liked this post by Max Headflow:
JamesH (06-02-2022),
OutlawFC222 (08-02-2022)
JamesH (06-02-2022)
Punching in all your numbers, I got you at 10.05 with a ccp of 201.76 psi.. What elevation you at? Cause that could make a difference in decreasing it . Going to the 527 cam will only drop your CCP 6 psi.. I agree with Max.. Stick with the 48's and get it tuned properly..
Max Headflow (06-04-2022)
