Inboard vs. Outboard
The service manual I have for an 02 FXST loves giving direction in terms of inboard and outboard for seating parts of the engine for assembly. I want to make sure that I'm understanding these terms correctly. First definitions. I hear inboard as something pointing towards the center of the engine. Outboard, the opposite, pointing away from center. Enter a specific example that confuses me.
The service manual states "Install lifters in the crankcase bores with the oil hole on the inboard side..."
That to me says that the oil hole should be facing toward the center of the bike. This would imply that when you remove the lift originally, the oil hole wouldn't be visible since it would be facing inward and away from you. When I removed all 4 lifters however, that oil hole faced out, towards me. Videos that I've watch on Youtube show the same thing. What gives?
Am I misunderstanding the term inboard? Am I misunderstanding the 'oil hole' referenced in the service manual? Has anyone else been confused by this?
Thanks -W
Thanks -W
I pay more attention to if one flat on lifter side fits better with the roll pin. I've seen it where one side is just a bit looser that the other. I choose the more snug side as long as it's not hard against the pin. Saw that once before also. Don't remember who's lifters it was. Otherwise it doesn't matter whether holes are inboard or out
