Primary Oil for early Twin Cam
I personally use Redline MTL
But people are quick to discredit ATF because it's only for A/Ts. Most manufacturers use ATF in their transfer cases, and guess what's in those? A giant CHAIN, and GEARS??? No way... I'd venture to say the transfer case in my truck is under a bit more stress than an HD.
The following 3 users liked this post by PureHybrid:
Many off-roaders use ATF in their MX and single tracks bikes transmissions. In my GG trials bike, ATF type F is the factory-recommended trans oil because it holds up better than regular oils with the sheer force of the gears. ATF is a very tough resilient oil to wear and heat in those applications, just like a car's AT.
My old TC has had the HD 20/50 in it and Hypoid gear oil, never did the ATF deal, no particular reason, just haven't.
https://www.harley-davidson.com/us/e...ant/p/62600004
running Formula+ and it works well. Tried other things, but, bike runs well w/ it (2008 Ultra)
I've never run it so take that for what you will.
The one thing they all agree on tho is type F ATF.
Max Headflow (04-24-2022)
Wrechar (04-24-2022)
