Twin Cam Motors Twin Cam 1998 thru 2017
Currently in process of my HO103 build.
Old 04-12-2022, 01:16 PM
12B-Retired's Avatar
12B-Retired
12B-Retired is offline
4th Gear
all i know is the guy at this shop, knows bob woods and the guy that owns revolution racing very well and with talking to them , they have some custom stuff for my bike being made that will allow all this to work so, not sure... gonna go with it and see just how it all works together i suppose. and get pictures and specs all along the install process to make sure.
Old 04-12-2022, 01:24 PM
chopper_man's Avatar
chopper_man
chopper_man is offline
Received 1,665 Likes on 990 Posts
One thing I see missing is you'll need a new air cleaner for the 58mm, only ones I know of are the S&S Stealth and a couple screamin eagle ones.
Old 04-18-2022, 10:38 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
That's not true. HPI for one.
preposter0ne (05-25-2022)
Old 05-20-2022, 02:10 PM
12B-Retired
4th Gear
got it back together, tuning in the AM, then the break in begins.
Old 05-20-2022, 06:04 PM
djl's Avatar
djl
djl is offline
Received 2,227 Likes on 1,611 Posts
Break in and tuning should be done on the dyno; very common practice assuming the tuner has the skills. I hope you replaced the crappy Trask filter. If not, the motor will stop breathing before peak TQ/HP. 60Gunner's 107 choked at 120HP; replace filter with K&N and hit 127HP.
Old 05-20-2022, 11:12 PM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is offline
Received 4,089 Likes on 2,043 Posts
Still curious how they got the 103 to a 113...hard to believe they went through the cost of splitting cases...boring cases to stop at a 113? Not that there's anything wrong with a 113 but it doesn't make sense in this case...to me anyway
Steve Helton 2 (05-21-2022)
Old 05-21-2022, 12:59 PM
Ericson38's Avatar
Ericson38
Ericson38 is offline
With the same 3.5 qts of oil as a 96 incher, what is the expected oil temperature get to when riding hard?
I wonder if the 107-114s have more cooling fin surface area than twin cam?
Old 05-21-2022, 05:10 PM
CHUDDLESTON's Avatar
CHUDDLESTON
CHUDDLESTON is offline
what is the K&N filter model that will work with the TRASK Assault? I tried one that another post suggested... but the K&N Filter was not wide (thick?) enough for my Trask assault on my Twin Cam 107" motor.
Old 05-21-2022, 06:47 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,016 Likes on 4,064 Posts
So is it a 113?
From FM.
The Fuel Moto 113" is a complete engine kit for 110" CVO engines
Old 05-22-2022, 11:44 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
It helps if you use the right filter. The K&N E-3226 is a perfect fit. Works great on my 107. No one suggested the E-3225 you apparently tried.
12B-Retired
Engine Mechanical Topics
05-20-2022 02:04 PM
Greg Di
Milwaukee Eight (M8)
27
07-16-2019 10:16 PM
354Hemimopar
01-03-2018 04:53 PM
m_mcdonnell314
08-08-2015 10:13 AM
BourboncityTroy
Exhaust System Topics
19
11-03-2013 06:22 PM
Quick Reply: Currently in process of my HO103 build.
