Twin Cam Motors Twin Cam 1998 thru 2017
Misfire on 03 fatboy
Old 04-08-2022, 04:41 PM
huey_da_jugg666's Avatar
huey_da_jugg666
huey_da_jugg666 is offline
5th Gear
Default Misfire on 03 fatboy
I have an 03 fatboy,converted to carb, has a basic Harley carb , turned on and idled fine, and then I went back to turn it on a few minutes later and it started having trouble starting,I gave it throttle and it stays on but has a bad misfire, sounds like very loud popping ,and as soon as I let go of the throttle it dies ,jets not clogged,I have no leaks, plugs aren’t wet , I have no idea what it could be . Help!
Old 04-08-2022, 05:39 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,016 Likes on 4,064 Posts
Could be a bad crank sensor. Let it cool off and try again. If it starts right up, bad crank sensor. I'd also check the plug wires. Make sure the ends are clean and no cuts.
Old 04-09-2022, 08:24 PM
huey_da_jugg666
5th Gear
I put a new crank sensor ,new wires ,new plugs , coils good, still not working. I noticed it only starts when I twist the throttle ,choke doesn’t make a difference, and soon as I let go of the throttle it dies. So it’s getting spark
Old 04-09-2022, 08:56 PM
Max Headflow
Does it sound like it's running on both cylinders?
Plugged pilot but choke should still work..
You may want to try a compression check. You might have a stuck valve.
Old 04-09-2022, 09:29 PM
TexasScooterTrash's Avatar
TexasScooterTrash
TexasScooterTrash is offline
Received 1,402 Likes on 859 Posts
If you just did the conversion and the problem started, go back and check what ya did. Intake manifold seals leaking? Does the enrichment (choke) system work? Does the accelerator pump squirt gas when ya twist the throttle? Twin Cams have Single Fire ignition . . .are the plug cables reversed?
Old 04-09-2022, 09:32 PM
Max Headflow
I think one thing to note is that the bike won't run at all, if the plug wires are reversed.
Old 04-09-2022, 09:34 PM
Max Headflow
Does it have a carb coil or efi?
Old 04-09-2022, 10:27 PM
huey_da_jugg666
5th Gear
EFI, I’ve had the bike a year,ran no problem at all.
Old 04-09-2022, 10:30 PM
huey_da_jugg666
5th Gear
the conversion was done way before I got the bike, I e had it about a year, and never had an issue, til just recently the battery started to drain ,and I started having this misfire issue since about 2 days ago. It just seemed so weird that it started up perfect and ran fine and then it starts misfiring this bad out of no where.
Old 04-09-2022, 10:33 PM
huey_da_jugg666
5th Gear
The wires aren’t crossed, the carb spits gas when I twist the throttle but bike dies immediately after I let it go ,choke works ,plugs have spark,wires are new , crank sensors new, still misfires ,sounds like gun shots
Quick Reply: Misfire on 03 fatboy
