Crankcase breather bolts
definitely over thinking this one. But on my 2016 street bob, using a SE breather. I’ve rigged up an external crankcase breather set up. My breather bolts have an opening of about 1/8”. But the opening at the very end of the bolt, on the end that screws into the cylinder head. Is a smaller diameter. Has anyone drilled this opening out to the same size as the rest of the bolt? What is the reasoning behind this opening being smaller than the rest of the opening in the bolt? I’m thinking it works in conjunction with the breather baffle, but I’m not sure.
98hotrodfatboy (04-16-2022)
holes
I drilled mine out to .060 bigger and the side ports on the bolts I opened up also. Again you wanted use common sense when you do this. Just open them up a little bit. Be sure to deburr them and clean and blow them out thoroughly. I used a small file to get the bur on the inside.
Harley1004 (04-20-2023)
fattboy1967
02-13-2011 06:11 PM
