Twin Cam Motors Twin Cam 1998 thru 2017
Hillside/Darkhorse 107 build
Old 09-05-2022 | 06:12 PM
JLOCKHART29's Avatar
JLOCKHART29
Only day and half off but got the motor in, tranny bolted up, all the mounts torqued and started putting odds and ends back on it. The guys setting the motor in for me wanted to go ahead and do it before I had time to do the in take. Having a jack to raise or lowered the engine getting it bolted in is a must do as reading the manual close. I spent 30 minutes trying to fish the pivot bolt on the back of the tranny threw. Could not get the spacer on the left side in place. I had left the 4 bolts holding the tranny to the case loose so I could have some wiggle room...wrong. Manual said to bolt and torque those 4 bolts 1st leaving the top motor mount loose. When I did this spacers slid in no problem. Also remember to install drive belt before installing pivot bolt.
The following 2 users liked this post by JLOCKHART29:
Flo-rida (09-06-2022), Harley1004 (09-16-2022)
  #52
Old 09-06-2022 | 05:09 PM
Flo-rida's Avatar
Flo-rida
Looking good
  #53
Old 09-07-2022 | 01:54 PM
60Gunner's Avatar
60Gunner
Why did you pull the tranny?
  #54
Old 09-08-2022 | 01:01 PM
SafetyFifth's Avatar
SafetyFifth
Cool build man, I like your attention to detail. Should be a strong runner.
  #55
Old 09-10-2022 | 10:13 AM
JLOCKHART29
Sent the cases in and had Darkhorse put in one of their cranks.
  #56
Old 09-18-2022 | 09:51 AM
JLOCKHART29
Man I just keep finding things. Assume run out in the old Crank did the rotor. Now I know where those shavings were from. Then went to install the coil and found front stud was corroded off!
  #57
Old 09-19-2022 | 02:06 AM
tdrglide's Avatar
tdrglide
I would look into cycle electric for rotor. In fact, I would look into one of their 3 phase systems. (rotor,stator,regulator).
  #58
Old 09-19-2022 | 10:13 AM
Max Headflow's Avatar
Max Headflow
It's a common problem with 03 up to the tc 6 speeds, Cut 0.060" off the bottom of the crank nut. The sleeve part of the nut bottoms out of the crank splines and keeps the nut from providing adequate clamping pressure on the comp/rotor stack up.
JLOCKHART29 (09-19-2022)
HTRAUD
04-12-2017 06:27 PM
EdandGrace
02-23-2014 09:19 PM
prostar
Exhaust System Topics
02-01-2012 05:20 PM
granddad
01-09-2008 09:22 PM
bosken
07-30-2007 03:50 AM
