Hillside/Darkhorse 107 build
Scott thinks he can source them for me. Just got my work sheet back from Andrew at Darkhorse. Looks like my lifter bores are in good shape. Surprised with that many miles on it. Can't say the same about my oil pump. Housing looks to be pretty scared. Was going to put a SE oil pump in since I have several K worth of rewards points but HD has about quit making things for it. 07 and newer pumps.
Be certain to have Dark Horse replace the case threads for the bolts. on their price sheet it's the last item under case work - Machine crankcases (ALL 8) stud insert upgrade $254.95. this will keep the engine together after the rebuild. you don't want to go forward with out it, the aluminum threads aren't standing up to rebuilds. I have two engines that the studs have pulled out one (124) within 3500 miles and a 110 within 6000 miles.
Carolina Dreamin' (04-20-2022)
Just my
60 Gunner, both cases used the OEM studs. One was built by HD local shop the other went to Dark Horse. They have a video discussing the issue and showing their response. Since this happened to me I did a search on this and other forums to find it is a common issue with rebuilds where the factory setup is disturbed. Aluminum just doesn't like being screwed with. Had similar issues with my all Aluminum Corvair Motor. Had the machine work been done by Dark Horse when the rest of the work was being done I wouldn't be sending the motor out to them for the repair 3000 miles after it was built. $260 would have been much cheaper.
The following 2 users liked this post by JLOCKHART29:
GREENOHAWK69 (04-27-2022),
Rick Matthews (04-19-2022)
JLOCKHART29 (04-19-2022)
Hmmm...be interesting to hear from some of builders here on how many motors they've had or seen with a pulled stud. Not doubting anyone here but it's just not something I've heard or read about happening "alot". I've had my personal motor apart a few times for various stages of performance upgrades, once for a darkhorse crank. Same ol factory studs with 75k on the motor...sure hope I didn't just jinx myself lol.
So while unfortunate, I don't see it as a widespread occurrence when using oem studs that stretch.
