Magnetti Marelli parts
Need some help finding replacement parts. Scoot is a 99 RKC with MM injection.
Took injectors out for service, and during reinstall the bolt for the "clamp plate kit" (as the Clymer manual calls it) snapped. The bottom part of this clamp kit holds the fuel pressure regulator, the top holds the injectors in place.
Included the picture from the manual for reference.
I need a new bottom clamp, or even the whole damn assembly. I've tried ebay with no luck, but I'm also not sure what else to call this thing when searching for it.
Any help would be really appreciated!
Received 22,216 Likes
From the 1999 RKS HD Parts listing: 99456-99B_486336_en_US - 1999 FLT Models Parts Catalog | Harley-Davidson SIP
Part # 27282-95 CLAMP PLATE KIT, fuel pressure regulator, w/ 27223-95 & both plates
Looks like Ronnie's HD may have them. Same as a 2000 RKS.
https://partsfinder.onlinemicrofiche...hdmc&a=332&b=9
Hope this helps.
Hope this helps.
I have a lot of NOS and like new take off MM parts including throttle bodies (OE and the SE 43mm), TP sensors and ECMs. If ronnies doesn't have it, you might just want to pick up a cheap throttle body off fleabay and maybe you will get a couple extra parts off it. Be warned that many will list them as fitting all years. The EVO MMs had 2 large and 2 smaller holes for air cleaner, the TCs had 4 same size holes.
Search Harley Throttle Body
If you can't find anything, let me know.
I have a lot of NOS and like new take off MM parts including throttle bodies (OE and the SE 43mm), TP sensors and ECMs. For that part, you might just want to pick up a cheap throttle body off fleabay and maybe you will get a couple extra parts off it. Be warned that many will list them as fitting all years. The EVO MMs had 2 large and 2 smaller holes for air cleaner, the TCs had 4 same size holes.
On another note, the upper injector seals..are they anything special, or just Viton O Rings? One was pretty stretched, so I'd like to replace it if it's pretty easy to come by.
Didn't realize there was a difference, but that makes sense. I appreciate the knowledge. If I strike out when I get ahold of the dealer, I will definitely let you know.
The following 2 users liked this post by anthony matson:
CoolBreeze3646 (03-29-2022),
Rob Harper (03-29-2022)
