Will 103 cyclinders off a street bob fit my softail engine , want to upgrade from my 96ci fxst
have cylinders pistons heads and 255 cams from a street bob 103
Might want to consider getting some compression releases machined in. The 255s do generate some cranking pressure...you may not need them all the time but on hot re -starts your starter and battery will thank you.
The 103 heads have compression releases built in. HD sells compression releases and a conversion kit for the 96. It has to be tuned for it. PV can do it. Or HD can do it with Digital Technician. I have it wired up on my 09 Softail.
70623-11
28861-07A
