Twin Cam Motors Twin Cam 1998 thru 2017
Carbon in cylinder heads
Old 01-25-2022, 10:33 AM
GOGOBECK's Avatar
GOGOBECK
GOGOBECK is offline
Old 01-25-2022, 10:41 AM
Morrid7's Avatar
Morrid7
Morrid7 is offline
Thank you for all the suggestions! I have the heads off right now because I installed an S&S big block kit. Old pistons did not have excessive amounts of carbon build-up. However, the rear cylinder head had noticeably more carbon than the front head, but I did not see a pattern to it that would suggest valve issues. Both heads had build-up in the same areas. The rear head just had more.
The new pistons sure do look pretty and shiny
Old 01-25-2022, 07:34 PM
Rocking_it's Avatar
Rocking_it
Rocking_it is offline
Received 1,293 Likes on 447 Posts
Old 01-25-2022, 09:52 PM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is offline
Received 4,090 Likes on 2,043 Posts
Man I thought I was bored...hopefully you took off the heads to do more than just clean them like Kirby said.
Old 01-26-2022, 06:12 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
especially if going big bore,leaving a lot of power on the table with stock heads
Old 01-26-2022, 10:37 AM
Morrid7's Avatar
Morrid7
Morrid7 is offline
I did decide to have the heads worked since I have everything apart right now and the money to do it. My heads are being decked about .035” and intake valves opened to 1.90. Resulting chambers will be 83cc and expecting a little over 195 psi compression.
SpOrTyStRoKeR
01-08-2021 07:10 AM
hdrider98ci
03-21-2019 10:31 PM
JJK16
Engine Mechanical Topics
09-16-2014 06:04 AM
run1fsr
Shovelhead
08-13-2014 06:41 PM
Bromano
Exhaust System Topics
08-31-2010 02:13 PM
Quick Reply: Carbon in cylinder heads
