TC88 build need feedback!!
So I just finished my TC88 build and I'm looking for feedback and what to expect as far as tuning goes and power numbers as well as if it was as put together as I thought it was for my riding style of let em hang....my upgrades included the s&s 100in power pack with 585 cams and entire cam chest, heads are ported polished 103 heads, 52mm throttle body with 5.13g injectors, 58mm single bore intake manifold (to match to the newer 103 heads) high flow intake and a dnd fatcat 2-1 pipe. I also have a power vision tuner that I got my baseline tune from to do some break in cycles and then some break in riding before I get it dynoed.....This was my first motorcycle engine build. I've been riding since I was a kid and now at 30 I've finally decided it was time to do a little build. Any and all feedback on my upgrades would be appreciated as far as what to look out for moving forward and what kind of numbers do people think it will bring. Am I going to be satisfied with the money I've spent? It sounds mean as hell hopefully its as mean as it sounds!!! All feedback appreciated
Received 22,173 Likes
I forget the guys name who did them but he's a bike builder out in Pittsburgh pa that I met at a swap meet in Atlantic City is where I got the heads. As far as compression the kit I got said one number and then there was a higher number if I used a certain gasket to up the compression ratio but without going thru all my paperwork I kept from the build I couldn't tell you what those numbers were off the top of my head I wanna say 11.something to 1
As far as the break in riding I'm just going off the paperwork that can with the stuff from S&S..I've done all the break in heat cycles and and oil changes but they said in the paperwork to do more conservative riding up and down thru the rpm ranges not being real hard on the throttle and not luging the motor. And getting a few hundred miles on it before the dyno. Like I said this is my first build so I'm open to any suggestions as far as all that goes I'm just going off the paperwork. I know when you build car motors the break in for them is driving it how you intend on driving it. Is that the same with these vtwins? Can't do any riding right now cuz I'm still waiting on an air cleaner for it from S&S. They sent me the wrong one twice...unless anyone's got an air cleaner for sale part number 170-0287....any other info you got for me as far as break in miles and tuning would be appreciated thanks!
Hillsidecycle.com (12-21-2021)
A good tuner can seat the rings on the dyno and go right into a full tune without any break in riding miles. The last two motors I built had two one minute heat cycles to listen for funny noises and check for leaks ant then straight to the dyno. It's a pretty common practice these days.
