Twin Cam Motors Twin Cam 1998 thru 2017
Can I run the bike without the gas tank installed?
Old 10-10-2021 | 03:49 AM
Adam76's Avatar
Adam76
Default Can I start the bike without the gas tank installed?
Hey guys, just done a full top end rebuild, cams, heads etc. Its a 2002 CV40 carbed fatboy.
I have everything ready including rebuilt and jetted carb.... can I test run the motor before installing gas tank? Only because if somethings not right pulling the tank is a major PITA.
Whats the best way to get around the vacuum operated line from the carb to the petcock - just put a blank off nipple over the vacuum barb on the carb??
Thanks for any advice.
Old 10-10-2021 | 05:32 AM
Jackie Paper's Avatar
Jackie Paper
Sure..you be surprised how far a new Harley battery will take you. Let us know how high a gear it will pull.
Seriously, what you described should work.
Be careful. What are you feeding the fuel with?
Old 10-10-2021 | 06:53 AM
Adam76's Avatar
Adam76
I'm not yet decided on doing it because I don't really see any reason why there should be problems with the build... I just hate pulling the gas tank...
I was just going to run a long piece of fuel hose from the carb attached to the bottom of a appropriate sized funnel filled with some gas. Make sure it starts and runs for one minute and then shut it off.
Old 10-10-2021 | 07:00 AM
Hoginedgewood's Avatar
Hoginedgewood
I have used a push mower fuel tank ziptied to the frame.
joe40x (10-11-2021)
Old 10-10-2021 | 07:28 AM
smitty901's Avatar
smitty901
IV bag of gas hanging on the bars may work. Good luck with your work.
Old 10-10-2021 | 07:43 AM
Jackie Paper
Don't like open funnel and hose pushed on it
Put it all back and run it. Your last post sounds like you know what you are doing.
Old 10-10-2021 | 09:05 AM
LQQK_OUT's Avatar
LQQK_OUT
One option is an auxiliary fuel tank.
https://www.motionpro.com/product/08-0032
Old 10-10-2021 | 09:10 AM
touchdown's Avatar
touchdown
Yes you can, maybe just put the tank on but don't install it until you know its going to run.
Old 10-10-2021 | 10:14 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Why not remove the rear tank mount bolt and loosen the front bolt. Lift up the tank from the rear and slide something under it to hold it up? Like a short 2x4 when I did my top end work. Hell of a lot easier the removing the tank.
Old 10-11-2021 | 05:58 AM
PeterB's Avatar
PeterB
...I was just going to run a long piece of fuel hose from the carb attached to the bottom of a appropriate sized funnel filled with some gas. Make sure it starts and runs for one minute and then shut it off.
That sounds really hazardous. Good way to torch your bike and the garage if things go wrong -- as they invariably do.
You would be better to just sit the tank loosely on the frame and hook up the gas line.
Or at least sit the tank on the bench next to the bike and hook a long piece of gas line hose with clamps between the tank and carb. I guess you would have to pull the diaphragm out of the vacuum petcock to let fuel flow.
And have fire extinguisher on hand just in case. You never know with a fresh start up, regardless of gas tank situation. Stuck floats, split lines, loose clamps, combined with a pinched wire or loose plug lead and woofah!
Quick Reply: Can I run the bike without the gas tank installed?
