Bank angle sensor problem
2014 FXDB
just completed a cam upgrade on my streetbob, going for initial start the Speedo gives me the tip code which I’m informed is for the bank angle sensor. #1 It’s been upright on a bike lift for 2+weeks #2Knock on wood I’ve been lucky enough to not have ever dropped the bike in my ownership. (Bought it new in ‘14) I’m assuming I might have jostled or even broken the BAS during my cam install. I also did a Speedo and ignition relocation and bluetooth speakers simultaneously so I was lengthening some wires here and there as needed. I’ve tried the reset procedures for the BAS as the manual recommends with no success. Turning the ignition on the fuel pump primes shortly then cuts out with the TIP code popping up on the Speedo. I’m not brand new to HD but I still have a ton learn. And tips or advice are greatly appreciated.
streetbobwhiteboy (09-30-2021)
